Re: mercruiser 250 6 cyl. interchangable with ?....
Hi RMarlow,<br />Yes you can,But you have to transfer everything over. The IO engine uses race<br />grade bearings on the crank & cam. Put in a<br />new oil pump. Use a Marine Gasket Kit. Also<br />the marine carberator.<br />Some times a good welder can weld cast depending on where it is cracked. If it is <br />internal-forget it.<br />...good luck...corm
