Okay here is one for Sherlock Holmes:
I have a 2004 Mercruiser 5.0 MPI SN OW003759 with Bravo 3 SN OW108118.
The two beeps per minute alarm is going off. Below are the facts of the case as I can best tell-
1) I can run the engine at 1800rpm for two hours (did it) with no alarm.
2) It only starts to sound when the boat is on a plane (RPM 3200 +)
3) When I back off the throttle to less than planing speed, even all the way to idle, the alarm will keep beeping
4) I can stop and immediately re-start the engine and the alarm will not sound until higher revs again (planing power)
5) If I run WOT for more than 5 seconds or so, alarm will become a continuous warning sound (not an intermitent beep). When I reduce throttle at all, it goes back to two beeps/minute.
6) All fluids are correct, engine is not overheating, oil pressure is 40-43, hard to tell from stock gauge but looks like 14.4 volts at speed.
7) At idle, in gear, engine will sometimes (with no regularity) speed up 100 rpms or so for a second or two.
8) It has also recently stalled while idle-ing at the dock a couple of times; starts right back up.
any ideas?
any ideas?
