semo549
- Jun 18, 2009
- 104
Hey guys all this waiting around for spring to get here has got me doing some thinking. First off I have a 77' Searay with gm250ci L6. The boat runs good and it has for 2 seasons now but it doesn't run great. The problem is with the timing. When I hook my timing light up the reading dances all around on the harmonic balancer. The timing is supposed to be set at 6 degrees TDC. Well the reading I get bounces around anywhere from 3-10 degrees so it is impossible to set it accurately. I have always relied on adjusting it to where it runs the smoothest. The problem is that I have always had bad throttle response. from idle to a quick opening of the throttle results in a starving like hesitation.
Here are the things I have checked:
-Dwell is set accurately
-accelerator pump is squirting fuel properly
-I have installed new rotor, cap, plugs, wires, and rebuilt the carb 2 seasons ago
-I might be missing a few things...
so is this problem most likely a caused from slack in the timing chain? I found a timing chain and gear set online for a pretty good price. Should I be looking into something else? new distributor perhaps??? Any advise would be appreciated. Thanks
