Gotta headcase from a guy, cleaned up the fuel delivery system, pump, anti-siphon valves, rebuilt carb, now trying to set the timing to what manual says is supposed to be 10Deg BTDC but cannot, seems to run much smoother set much more advanced than that. I have seen some comments here saying the advance should be set to 20 or 21 degrees??? Is that correct?? what's the best way to set this up so the engine runs smooth and clean. My gut says get it to idle smooth and run steady without hesitation throughout RPM range and ignore the 10 deg BS. Comments??? How can I confirm 20/21 degrees with no timing marker?? Thanks in advance!!! Skyfox
