Just got done removing outdrive on merc 4cyl 224ci w/alpha 1 gen 1. Successfully replaced gimball and all bellows.<br /><br />No sooner did I get shift cable adjstd and back in water, o/d started whirring instead of going in to fwd/rev. <br /><br />Pulled boat from water and shifter appears to be moving the shift lever properly, but I am able to turn the prop by hand when in gear. In one direction, with clicking, in other direction, with rubber-on-rubber squeaking noises. Is this a sign of lower unit damage or should I take the o/d back off and take inventory?
