I just traded for a McCulloch 9 hp s/n 800366. Needs a impeller is napa # 18-3009 the correct one if not were could I find one. Also were could I find a kit to rebuild carb. What is correct fuel mix. This motor has electric starter. Motor turns good has good spark (jump about 1/2 in.) will run a little with gas pumped into piston. Any idea carb adjustment settings. Nice little motor would like to see it run again. Thanks for all advise. ps Motor has good compression.
