mariner 2b impeller change
onka
Hi my first forum. removed bolts,smacked with mallet and the pin on the driveshaft bent the face plate and broke seal. how do you re-assemble because if you put the pin in it won't pass over the new seal and faceplate.If you slide the housing up and assemble the you can't tighten the bolts on top.
Does the driveshaft have to be removed and then pushed back up with the impeller assembly and pin attatched.:confused:
