Re: Manifolds
Look at the bottom of the manifold in the pics. There are ports where water is force through. Typically the water goes through the water pump on the front of the engine, through the block, and thermostat, then into the bottom of the manifold and out through the elbow, pictured also, on top of the manifold.
The reason this is done is because there is not much air circulating around the engine, like a car, and so the exhaust manifolds would get very hot, likely causing a fire in the engine bay of a boat, so water is circulated around them to keep them cool.
The problem, which is worsened with salt water, is the water in the manifolds and elbows corrodes the inside of those parts and when the metal corrodes it expands and come apart, causing restrictions in the water flow, causing an overheat condition.
Stainless is a great idea, but besides being expensive, still is not forever. I was checking into that last week and when I searched I found people discussing their stainless manifolds lasting about 7 years, in salt water. Perhaps in fresh water they would last much longer, but I have not seen any discussions regarding that.
Stainless headers brings you to the same problem as auto manifolds, they need a lot of air around them to cool things off. The "headers" I have seen for boats are set in engine bays that are wide open, for air flow, and still have a port on them to spray water in to cool the exhaust gases.
Chris
