TrenchFisherman
- Apr 7, 2002
- 218
Having spark issues on my 95 Johnson 112. After watching several videos on you tube I saw one that said make sure I don't have any voltage going through my kill circuit. Well when I disconnected it from power pack I was getting 12volts. So I pulled the red plugs apart at the motor and under the dash. Well the one under the dash had corrosion and I think that was causing the voltage to the kill circuit. When I tried cleaning them I broke off several prongs so now I need to fix them. What type of connectors should I use and what gauge is the wire? The red wire is a little thicker than all the other colors. I plan on just cutting off both ends of the plug and just using connectors.
