Re: lower unit oil types
From what I understand, the High Vis. is for Modern Outboards. The Hypoid 90 is for some older outboards and most Sterndrives. Type "C" is For outboards and stern drive units with "electric" lift mechanisms. As for Viscosity, I have no Idea what "Weight" they are, except that I do know that Hypoid 90 is heavier than the standard High Viscosity. '90 is something you would use in a differential in a car! What I do know is that I have always used Lubrimatic High Viscosity in the Boats that I've owned and never had a lower unit problem. I also use there T&T fluid, with good results. I guess it's OK! Use what you are comfortable with or you will be forever asking "What If", when it breaks!
