the_nstag8r
- Jul 29, 2003
- 4
I have 100 hours on an 2001 Johnson 225. I was cruising along at 5500 RPM's and immediately had a loss of 500 RPM's. At 2200 RPM's I get a little stumble. I have changed the fuel filter, spark plugs, "idle switch", prop and fuel. I have also cleaned my carbs. I can get my RPM's back by reducing the prop pitch but I can't even pull out of the hole. So, I have gone back to the 15x18. My next step is to replace my fuel tank vent and clean out the line and make sure the throttle cable hasn't slipped. <br /><br />It is pumping water and not running hot. It is burning blue smoke. So, the mixture looks good. I get no warning lights.<br /><br />What else can I try and why do you think this happened?
