Pacifictaca
- Oct 26, 2011
- 5
Is it normal to loose some air pressure if your sib sits on a trailer in storage units?
What pressure did you have it blown up to? {You want to not have it more than 3/4 of max pressure to prevent over-inflation with temperature increases.}
As already stated, you will get pressure changes with temp changes. You aren't really "losing air" in that situation, just losing pressure due to the cooler temp.
Yes, you can check the valves, seams, entire boat with soapy water.
Over how long of a time period did you notice the apparent air loss?
Yes. Fluctuation in temperature inside the storage unit can cause the perception of air loss. Or, the boat may actually have a leak. Start by checking that the o-rings are healthy and that they air valves are properly tightened. Soapy water sprayed liberally will help you find leaks, if any.
Larry
