seanymph85
- Nov 5, 2013
- 199
I just discovered that the live well pump an older Mayfair 2460 through hull/transom unit does not fit correctly on the inside of the aluminum boat I have. It may explain why someone had put so much silicone inside and outside of the boat in the area the "pipe" goes through the transom. In this case the hole for the pipe on the outside appears to be a similar or very close to the same position from the bottom as the drain plug.
When the pump is installed through the "pipe" hole in the transom, the side of the pump that faces the top of the transom is against the inside of the transom at the base of the pump but the opposite side facing the bottom of the boat is 1/8-1/4" away from the inside of the transom. So the base of the pump is not facing flat against the transom on both the side towards the bottom or the side facing the top of the boat.
In any case I either need to purchase a pump with a smaller imprint so the base where it in this case goes through the transom fits flat or tight against the transom all the way around thus helping to form a better seal assuming a seal is on the inside of the transom where the pump is as well as on the outside of the boat. The hole size for the pipe is very close or precisely the size needed as the hole itself fits fairly tight around the pipe all of the way around it.
I am trying to avoid having to have the hole moved to accommodate a good fit on the live well pump. Again short of finding a pump with a small imprint compared to this one I would need to somehow plumb the existing pump with and slight offset to move the largest diameter on the pump further away from the bottom and thus hopefully allowing the pipe on the inside of the transom to be sealed better.
The pump is out now so I could provide a picture showing the exisiting hole location for the pipe where it goes through the transom or provide some dimensions of existing pump if that would help. Sorry I know this post is long but tried to describe the situation as best I could to hopefully better enable suggestions on pumps or plumbing changes that could be made
