bigrobandjane
- May 20, 2012
- 6
......Not sure what came from the factory, but I have a livewell with a hole on the bottom that you can plug.
It will fill up (if you put the plug in) when you turn the switch on. If you pull the plug the water will drain like it should.
Is there a way to keep fresh water in there to keep the bait alive , or is there a way to circulate the water without your bait going out the hole on the bottom ?
I have read on some livewells that there will be 2 holes and one of which is an overflow to circulate freash water , but I could Not find anything like that on mine.
This is the 1st boat that I have owned that has a live well so I am sorry if this is one of those "no brainer" questions !
An "old timer" I know said to freeze a 20 oz soda bottle and throw it in the live well and that would keep your bait alive alot longer, but I am looking for a more permanent solution !
any suggestions would be great !
