386kustoms
- Mar 23, 2013
- 2
first off let me just say this site rocks. i purchased my first boat about a month ago and on these forums i have learned a lot. now i bought a 62 aristocraft w the original evinrude 75 outboard. the boat is definitly a project and no one around here will work on the old evnrudes... trust me i called at least 8 different places. now the solenoid was not working so i purchased a new one on line. installed it and the engine cranks fine with the key with no plugs in it. i checked for spark and all that jazz and everything seemed ok. so i re installed the plugs and when i crank the engine it turns very very slow. yes i have a batter charger hooked up to the battery as well set on 12v high.
i noticed when cranking only about 9.5 volts are getting to the starter, followed the wire down to the solenoid and while i crank 12 volts are getting to the solenoid but only 9.5 are leaving it going to the starter. is that normal? i thought the starters got 12v to it while cranking. could the solenoid be bad that i just purchased? any way to test?
