Johnson Paint
Beakster
Engine block is ALUMINUM !
ok my mistake. So use that paint for all of it? I guess I need a primer for the plastic bits but the aluminium parts and steel bolts can all be direct to metal?
saltchuckmatt
Clean it super good, sand and scuff up the existing paint, marine primer on all bare metal. Then numerous coats of desired marine paint. Clear coat.
Oh, I left our mask it.
Paint, 90 percent prep 10 percent paint.
909
attachment.php
909
The finish is extremely glossy and in my opinion a top coat isn't needed.
Beakster
thanks thats good to know....
Should I use a primer when applying to the engine block and/or the lower unit? How about when painting the cowling?
909
Prime bare metal, otherwise scuff the existing paint.
