So here is the problem. The engine runs for a couple of minutes then after a while it begins to rev up then die. As it is about to stall out it picks up and revs up to speed again. It repeats this quite violently untill i kill it. If I wait for 5mins or so it starts up fine and starts to do the same again. I have done the following:
Changed the head gasket,
Cleaned the carbs - although I may not have done this well enough they seemed very clean.
It was doing this before both of the above were done, and after I had changed the head gasket I ran it on muffs for 30minutes so I could re torque with NO problems at all. Took it down to the coast and the problem returned after I had put it in gear to sort out the idle etc on the throttle,
Any ideas would be appreciated
Thanks
Thanks
