Engine was in storage several years, I revived with new, non ethanol gas, etc., and carb 'boiling out', plus disassembly and meticulous disassembly and reassembly of the carb. Starts great, runs great -- to a point.
At about half throttle, the engine coughs and dies, but up to that point, idles and runs perfectly. If I snatch the throttle back, it recovers and runs well -- to that same half throttle point.
The carb WAS equipped with a .50mm pilot jet. I happened to have a .68mm pilot laying about, and installed it, expecting the engine to run way too rich, but it runs almost perfectly -- it still has a tiny stumble in the transition from mid range to WFO, but otherwise pulls like a mule all the way.
This engine has a fixed idle jet -- no adjustment, and its accelerator pump, while present, is disabled from the factory with a welch plug installed right in the output. (all the other accelerator pump hardware is in place)
I know these engines left the factory about as lean as can be for emission purposes, but I would have expected to remedy the half throttle issue with a jet just a few notches fatter. The change from 50 to 68 pilot jet has me concerned that there maybe an other issue(s).
Comments appreciated.
