Re: Is there a good way to text funtionality of a dual battery switch?
First, the switch is normally connected as shown below. Next, set the switch to OFF and measure the voltage between the COM terminal and system ground. It should read 0 (zero). Next set the switch to BAT #1 and measure again. Voltage should be +12 volts. If not, there is a problem. Set the switch to BAT #2 and measure again. Voltage should b3 +12 volts. Set the switch to BOTH and again, voltage should be +12 volts. Next, disconnect the POS battery cable at either battery. Set the switch to BOTH and measure voltage. If it is 0 (the battery that remains connected is not properly connected to the switch or is dead. You can repeat this test for the other battery and again, in the BOTH setting, disconnecting one battery or the other should still produce +12 volts at the switch. With two fully charged batteries, and reading of zero or significantly less than 12.6 volts says there is a wiring issue.
