Re: intake manifold gasket question
If it is a composite gasket, there may already be a sealant ring around the ports. The only gasket you should use sealer on is the old fashioned steel gasket. And even then just a light spray of the copper seal-a-gasket. Or a coat of spray paint will work just as well. None of the multi-layered composite gaskets need sealer and you can actually ruin them by using sealer.
Stan
