insulation for outboard motor cover?
Status
Not open for further replies.
fsutim
I recently riped out all the insulation out of my 1978 Johnson 70HP motor cover, it had started to make a mess and it didn't help when I found some bits inside my carbs. Does anyone have any ideas about re-insulating the cover? What kind of insulation I should use, and what is the best way to install it?
codkiller
Re: insulation for outboard motor cover?
FSU-Tim, I purchased some of this stuff for a 200 Evinrude. The kit comes complete and works great.
Dhadley
Just make sure your vents are still open. Trapping sound can trap heat too.
cobra 3.0
Wouldn't those blue camping pads be a heck of a lot less money!!! :eek:
ob
Some 1/4" carpet padding and contact cement might work as well.
dajohnson53
The noise reduction products that a previous poster referred to are more than just foam. They are usually a laminate of closed cell foam and a layer of either lead or heavy vinyl - to provide mass to deaden certain frequencies. It is designed in this way to work better than simple closed cell foam like a camping pad or closed cell rubber.<br /><br />Another factor that is important in sound deadening is to close up all gaps. The difference between a 99% closed space vs. 100% is quite a bit. If you don't think so, check out the difference in the sound that gets through a totally closed door or window, vs. one that is cracked open just a bit.<br /><br />That said, a lot (most?) of the noise from an outboard comes out the lower unit. This is *especially* true in my case - I run a jet. In addition, because of the need to keep the air intake open, you can't completely sound-seal an outboard cowling. Therefore, while the use of the sound deadening foam will no doubt reduce noise as advertised, it might not be as noticable as you would hope. <br /><br />Now, this opinion is based on thinking about it - not actually trying it. I would try it, but this stuff is heavy and with shipping to where I live (it's not available locally), I decided to try something else.<br /><br />By the way, I did speak with the guys who design and sell this stuff and they are great and will try to provide what they think is best for any individual application.<br /><br />I look at the foam inside the cover of my old motor and gotta think that almost anything would be an improvement. What I have is very thin, open cell foam with a lot of gaps. I bought some fairly heavy weight closed cell black rubber foam from a local industrial supply and plan to glue it in some day. If I ever do, I'll report if I hear any difference.
dajohnson53
PS: re: camping or carpet pads. The thing that comes to mind is that carpet pad would probably soak up water and oil and I don't know if camping pad would deteriorate from gas/oil or withstand the heat. As I said in an earlier post, I found some heavy duty black rubber closed cell foam at an industrial rubber supply company and it was pretty cheap.
ItsMeJazza
Hi I have 2 Evinrude motor covers that has been standing in the sun for about 5 years in storage and now I'm wanting to use the boat and get everything fixed. What is this rubber stuff you know and where I can get it to do my covers. Thanks
MODERATOR EDIT: Please review the forum rule about posting to old threads. This one is 20 years old.
Status
