Hi since I started reading this site I have somehow become the family marine engine repair man. I am still trying to figure this out, but anyways.<br /><br />I have my brothers 1963 model 110 9.8 hp outboard in my garage for a yearly tune up. The problem I have run into is the impeller key is different than the one in the water pump kit I ordered. The lower unit and impeller was off when I received the motor, and the old key is no longer available. But the key in my manual shows a 1/4" or so slot in the shaft, while the 1963 has a round hole in the shaft for like a pin to go into. <br /><br />Is it possible to just manufacture a pin and if so out of what material should I make it. If it is not recommended can this single key be ordered seperatly.
