Hydraulic crimping tool for battery cables
fishrdan
I'm looking to buy a hydraulic crimping tool for battery cables, automotive and boat. I've never used a hydraulic crimper, but they look like a better option than soldering on cable lugs. I don't have an issue soldering on lugs, but have a project that a crimper would work much better than soldering (and possibly melting things close to the cable).
Will an 8-ton crimper be sufficient to crimp up to 4/0 gauge cable? If not, what will fit the bill, 10 ton, 12 ton, 16 ton? I doubt I'll be crimping 4/0 gauge cable, more than likely 00 gauge or less most of the time.
Are the HF hydraulic crimpers any good, Ebay. Any horror stories or models to stay away from? I'm not looking to buy a high dollar crimper, something in the $30-50 range.
Suggestions?
fishrdan
Thanks Sam, that's one of the models/sizes I was looking at, and glad to see it worked well for those heavy cables you were crimping. Appreciate the thread link, it answered a bunch of my questions.
MTboatguy
I use the HF ones and have been for over 10 years now, when I was helping out at my buddy's camper shop, they got used a lot and held up just fine.
poconojoe
If you're just doing a few crimps, you can get a manual one that you hit with a hammer. This is what I did and it worked great.
EDIT:
Whoa! Those hydraulic ones are way inexpensive! I just looked them up. 10 ton kit for like $40! No brainer...buy the hydraulic one! I'm used to the very sophisticated super expensive units I've used as an electrician. (I'm retired now)
sam am I
EDIT:
:thumb:
fishrdan
Looks like I'm going with the 10-ton model. Thanks for the input guys!
I know where you're coming from. The RJ45 crimping tool I have was $80, 20 years ago, but it's top of the line... I bet it's still working perfectly fine when the $40 hydraulic crimper has made it's way into the trash bin.
