Hello. First post here, hopefully I'm putting this in the right section.
I recently picked up this used 1994 Monterey 19.2 Sur. The railing has come unattached on 2 of the mounting points. What I can't figure out is how this mounting system was ever supposed to work to begin with. They appear to use a bolt that goes down into the fiberglass and all that's sticking up is a 1/2" nub. It looks like a previous owner had tried to repair it with some JB weld putty stick type stuff and it didn't hold.
I went over to West Marine yesterday to pick up some of there brackets and it doesn't look like any of these will work because the mounting surfaces are not flat.
So far, the best thing I can come up with in my head is to drill down into the bolt, tap it for a machine screw and then drill a hole through the railing tubing to bolt it down. Is there a better way to fix this?
Thanks,
Dan
Thanks,
Dan
