shift into full fwd, remove the outdrive
unhook control cables. harness plug, all battery cables, fuel line
remove the 2 rear housing bolts, remove the front mount or bolts/lags
loosen exaust rubber coupling
pull engine up , remove rear housing bolts and cover
remove coupler from engine/flywheel
reinstall in reverse order
