how to repair leaking transom
19bwb67
hi, mid 70's starcraft aluminum w plywood transom. 60hp johnson outboard. water is getting in and i'm assuming it is the transom. Any suggestions on proper repair appreciated. caulking, sealers, adding rivots, etc??
thanks, Brett
wolfspyryt
Re: how to repair leaking transom
Could you post some pics of your transom ... inside and out? Perhaps I could help you. Check out my transom thread here ... Transom Trouble
Joe_the_boatman
You might want to do the "water test" to see if it really is the transom leaking. While trailered, fill the hull w/ a few inches of water and look underneath at the hull for drips. If none, you'll know the bottom of the hull is sound.
When you find the leak (hull or transom), seal w/ a pop rivet w/ a dab of 3M 5200. Should last a long time.
Previous owner of my boat slathered silicone outside the bottom rivets of the transom brace. It leaked bad when filled w/ water.
Another solution is "Glu-vit" from the inside, if it's the hull that's leaking.
If it's leaking at the transom, also check for wood rot, and treat it before it gets worse. Ethylene glycol (antifreeze) kills the wood rot fungus.
