I am worried that I am "over-propped" on my 1989 Evinrude 150, because of low WOT rpm readings. I am trying to borrow a hand-held tach or timing light w/tach to check my tach reading (is there any problem with using an automotive one with the CDI ignition?), but was wondering how someone determines what propeller is appropriate for the boat and motor to get the approp WOT rpm range? Is there a chart somewhere or website? The motor is an E150STLCEM on an 18.5 ft center console w/ max load of 2000 lbs-- i use it mostly for freshwater fishing for lake stripers, but also pull the kids on a tube with it sometimes. Any advice is greatly appreciated!
Also-- in case the loaner tach doesn't show, is there a way of checking the tach with a voltmeter or multimeter to see if it is operating correctly?
Thanks!!8)
Thanks!!8)
