Re: How to check where water enters the hull?
good point on that little tube possibly leaking pack-rat. mine must have in the past as when i got it, that area on the outside is goobered up with sillycone.
that tube ya see goes from where ya see it on the outside up to the ft. bottom of the center window panel pocket. i always wondered where the center panel disappeared to when sliding it down. well, one day i had my cat onboard and lost her at sea. couldn't figure out where she went. found here on top of that pocket. only the attached leash gave her away. imho. that tube is to let water out of the center window pocket. there really aint a seal at the center panel of the window so rain easy gets in that area. that drain tube that leads to the outside of the hull by the bow eye is the drain tube for that window pocket.
you gotta crawl into the little space under the windshield.
thats fun to do isn't it...
a real back breaker for sure...
i get a little water in my bow area. my best guess for where it leaks on my boat is the bow light. i can see the trickle, right by where that tube enters the boat, but i don't think it leaks because the only time i get water in the bow is after rain or high seas where i'm splashing water on the bow itself.
i also resealed the ft. half of my cap to hull seam. at the rub rail. that glue had degraded on mine. mostly the ft. half which is why i only did the ft. half the boat.
fwiw. my boat don't take on any water if it's calm out. not unusual to remove the drain plug at end of day and get nothing out of it.
in higher seas i'll get less that a cup out. when i'm out in the stuff i can drain 1/2 gallon out maybe up to a gallon. never had more than that and assume that them days the water has intruded via splashing right into the boat from the high waves.
great to have ya on board pack-rat
