glenn property of pam
- Feb 17, 2012
- 2,906
boat had silicon in the back on the stringer side that was painted the same color as the rest of the inside back. this made me curious so i pulled it out to find a shallow hole drilled into the stringer i guess that it was a inspection hole. wood is solid so thats a good sign but whats the correct way to seal it.....i have epoxy resin and 6oz cloth and i was thinking pb (dont realy understand the talc bit) or marine bondo then a few bits of 6oz over it but do i wire brush first or grind or use a cemical to clean it first?
sorry about the white powder its insecticide after i found some type of larve on a piece of wood in the back and kinda freaked that it might have been termites - woodworm or something and i didnt want them there as i had just exposed it by pulling out the silicon
p.s dont fell bad if you carnt understand my spelling spell check couldnt either
