How much oil in 4.3l mercruiser?? please help
Status
Not open for further replies.
fontenot41
I have a 2005 vip vegas with mercruiser 4.3l. Motor serial # 0w017581. I am changing the engine oil. I drained old oil and have put 5 qts in and its still not showing up on dip stick. How many qts does it take?? please help as I've searched this forum for the last hour and cant find an answer. ( and yes I did put the drain plug back in lol) first time boat owner.
Ayuh,.... I dump in 4 quarts, start it, run it a minute, shut it off, 'n top it off to the full mark, which is usually 'bout 4, 1/2 to 5 quarts,....
fontenot41
yea I don't understand. 5 qts and its not even touching the dip stick. I blew in dip stick hole and heard it bubbling, so it's not plugged there. the ONLY thing I can think of is would if the previous owner changed the dip stick with the wrong length dip stick.....can someone that has a 4.3 measure the length of their dip stick. i just bought boat a week ago. It looks like motor had about 7 qts that came out.
fontenot41
local dealer is saying part number for the dip stick 86194216....can someone tell me how long this dip stick is suppose to be
Bt Doctur
fontenot41
yes its level. I even tried jacking it up as high as I can with a floor jack and also bringing it all the way to the ground and still nothing.
fontenot41
THANK YOU! for that picture. I have the one on the right and Holly crap that says its suppose to be 27.5" Mine is only 20"
Bt Doctur
google "mercruiser manual 25 in pdf"
you will fine 23, 24 and 25 available
Bt Doctur
just joking about the extra oil. if too high the crank aerates it into foam and you lose oil pressure
not a drawing, straight from the manual
FreeBeeTony
Something in those dwgs don't make sense.
​There's a difference of ~11" between the 2 dipsticks from where the stick hits the top of the tube and the full mark.
Or am I missing something?
poconojoe
Ok, just got home and measured mine.
From where that yellow rubber seats on the tube to the very end is 20-1/8" .
My 4.3L is a 2003 model serial # OM643729.
Oh, mine is the one on the right in the picture from BT.
Status
