How Long should Resin cure before sanding?
NathanY
Gonna put a fresh coat of resin on the floor of my boat, (bondo brand at Lowes) and need to know how long to let it cure before I can sand it smooth.
ajp
Re: How Long should Resin cure before sanding?
Until its dry.<br /><br />Depends on temperature, amount of hardner, etc.
NathanY
Well it generally dries in about 1 hour give or take. So it would be alright to sand then? I have never sanded fiberglass, it usuall smooth, or I dont worry about it. But I like this boat, so I want to do it right.
plywoody
As soon as it is dry is fine. It is a one way reaction, and sanding will not affect the reaction in any way. Actually, the quicker the better, as it will sand easier the greener it is. (as long as it is not sticky, of course)
Hawkeye1
The thinner it goes down the longer it takes to dry. I have seen it take 1/2 a day to cure in a thin coating like you are doing.
plywoody
If it takes a half day to dry, you will have a temperature/catalyst problem.<br />There is no way properly mixed resin at normal temps (70 deg F) will take a half day to dry.<br />Unless you have some real stale resin.<br /><br />Take a little sample, in a throw away measuring cup, add the proper amount of catalyst (usually 1.25%) and time the length of time to gel.<br /><br />It should be about 30 minutes.
Hawkeye1
Plywood, he is coating a deck I belive. Should be a fairly thin applacation. Now I quit using poly resin years ago but it seems like it took way longer to hit when it was spread out thin then if you let it pool a little. I agree it shouldn't take 30 min if its in a somewhat of a mass. Epoxies take even longer to hit when spread out but its a whole different reaction as nothin is evaporating like the catlist in the poly resin.
NathanY
If this helps, I plan to use a full gallon on an area 4'X 3' plus woven mat.
Kenbo
Nathan, I am not familiar with the term woven mat, however without any fiberglass at all, spreading a gallon over a 3 x 4 foot area will result in a uniform coating of resin approximately 1/8 inch thick.<br />Fiberglass material most commonly comes in 3 types, random strand mat, cloth, and woven roving. Random strand mat has no weave at all, and as a result has less strength than either cloth or roving. Fiberglass cloth and woven roving are both woven fabric, the roving being a much heavier weave. Kind of like comparing canvas to heavy burlap.<br />Depending on the type and weight of the material used, one gallon of resin will wet out from 32 to 64 square feet of fiberglass.<br />With regard to sanding, if you attempt to sand too soon upon resin cure, you will just clog up your sandpaper real fast. But this will become evident rather quickly. Hope this helps. Good luck :)
NathanY
Sorry bout that, I meant to say woven cloth.
Kenbo
Just curious, how many layers of cloth are you going to use? What kind of surface finish are you trying to get? :)
NathanY
One layer, just trying to get a smooth finish to carpet. Just dont want any lumps.
Kenbo
You probably won't need to use more than about a quart of that resin for 12 sq ft of cloth. Make sure you have a clean smooth surface to start with and pick out any debris before the resin starts to cure and your sanding job should be pretty easy and minimal. Good luck! :)
