How do I know its fixed right?
ccbangler
OK, I replaced the water pump in my '88 45hp merc, and put it back together, everything seems ok. I am going to test it tonight after work, but how will I know if everything is sealed and working as its supposed to? Its easier with a water pump in a car, you just look for leaks etc. But Other than it pushing out water and the pressure guage, is there something else I should be on the look out for? Thanks<br /><br />Edit >> Also, what should the water pressure be?
petryshyn
Re: How do I know its fixed right?
If the impellar was in one piece when you changed it out, watching the water pressure is a good indicator on the job you did. If the impellar was fragmented, you better be monitoring temperature for awhile as well. Any impellar pieces unaccounted for can cause grief. <br /><br />I believe the pressure should be between 7.5-14psi according to teleflex...... :)
ccbangler
Cool, thanks!<br />I tested it yesterday, and it seems good.<br />The impeller I replaced was in one piece and wasn't missing any rubber when I took it out.<br />The psi ranges from RPM right?<br />Thats what is does now, and is low when idleing, but I think its because of the low idle. I dumped the gas (was a year old) and am going to put some fresh clean gas to see if that was the idle problem, I couldn't get it up past 4500 RPM either on full throttle.<br />(new boat to me, just got it a week or so ago)<br /><br />Thanks! :D
