Re: Hotroding the Ford 460
Wide Open...<br />1st, IF YOU ARE GOING TO BUILD A HOT ROD..<br />Start with ta SOLID bottome end. Horspower is made in 2 ways, Displacement and fuel management. So Big Cubes and lots o fuel. <br />Or where any old wrench will tell yas, power is made in heads, i.e. combustion chamber. A set of heat ported and polished and put on a flow bench will give ya the most bang gor the buck! Bolting on a big carb without chaging cam and timg is jut like peeing in the wind. The move that fuel and bun it it must go through the head , get ignited andthen exausted.
