Hondon & Maui Girl, Still on the THREAD!
Rock Man
Ya! have plenty of fuel comming out of carbs, Gearcase oil looked good was going to replace this spring, won't stay running long enough to put in gear... Going to do stator test, switch box test, ignition coil test tomarrow. Do you think it could be one or more of these or am I wasting my time? Just was hoping that it was something simple. Not my luck. Never got into under flywheel stuff before but am willing to learn. Still have samething, starts up but won't run longer than 2 to 5 seconds... Sounds good when it does run to this point. Has me stumped big time. :confused:
captsara
Re: Hondon & Maui Girl, Still on the THREAD!
I am an operator, not a wrench, so please forgive me if my ideas take you backwards. It sounds like your experienced and understand your systems.<br /><br />This is just some stuff I've seen work.<br /><br />I'm sure you've tried opening your throttle, maybe to about half way, with the shifter in nuetral and cranking it. Just be ready to throttle back if it goes.<br /><br />I've never done this one myself, but I've seen my Harley Mechanic spray short spurts of something (carb cleaner or starter fluid perhaps) around the intake manifold gasket. If its sucking air it will pick up this fuel and try to run. Get more info before attempting that one please.<br /><br />Lightly tapeing the side of the carb (to release a stuck float)<br /><br />Make sure exaust ports are clear.<br /><br />If possible, watch your fuel filter while running, look for bubbles. Hold a flashlight behind the bowl, if its glass or plastic.<br /><br />make sure your fuel jets are clear.<br /><br />Question: when it dies does it sputter like its starving for fuel, or can you smell gas, indicating flooding. <br />Some motors have a high pressure fuel pump for starting and a mechanical fuel pump for running. I would read my manual and look for anything that could fail.<br />If your distibuter cap and plug wires are suspect at all i would replace them.<br />Testing the voltage on ignition from both sides of the ignition switch is a good idea. You'll figure it out. I've seen this a few times in my career, and it almost always turns out to be an air leak in the fuel intake. They can be a ***** to find too. <br />One more idea, if your motor has a brain, turn everything off, diconect the batteries, unplug the brain and replug it. Bill Gates would like that one.
SeaDawg
Rockman, I don't want to bust your chops, but reply back to your same earlier posts. don't keep starting new ones.<br /><br />It'll bump it back to the top of the list, and won't drive the rest of us crazy trying to read the posts here.<br /><br />Thanks.
