2001 Honda 2hp 4-stroke model BF2D. Every time I used this engine, including the last time I used it 2 years ago, I turned the gas off and ran it dry. The last time I used it (2 years ago), I ran the tank completely dry. I did not use the drain on the bottom of the bowl though. Then I put it in a dry, heated storage area.
Today I cannot get it started. I put a new plug in it, and I get a yellow (def not blue) spark, and after several (dozens) of pulls the plug does not seem to have gas on it when pulled. I have checked that there is gas flowing through the carburetor drain screw. I have read that the carburetor jet is so small that it cannot be cleaned, but then I also have read a lot of other less than factual things on the internet. Any comments and/or ideas here?
Thanks in advance.
Thanks in advance.
