Help! What is this?
tank1949
I bought an older SR Amberjack that has been retrofitted with Mercruiser Bravos and 383 Strokers with Thunderbolt 5 ignitions. The AJ has had 4 or 5 owners over lifetime. Past owner couldn't identify what is in photo. I believe it is a motor audio alarm? I believe person who installed TB5 ignition disconnected it, but I am really not sure. If anyone has schematic of what wires go where, please provide. There also appears to be two three wire plugs (assume alt. oil and heat switches), but I am not real certain how they connect. Help!
jimmbo
Warning horn for oil pressure, water temp is my guess
muc
"Retired" Association of Marine Technicians...
That's the controller for engine synchronizer gauge. It is usually a 2" gauge that is usually between the tachometers and tells you how close the engines are to each other in RPMs. Under the red plug will be a slotted screw to adjust the gauge. Might find a wiring diagram on the Teleflex website. I think all the newer sync gauges have the circuitry built in them.
tank1949
Sorry, I didn't get back to u sooner. I have been replacing rot that a so-called qualified marine surveyor missed. Boat came with Flomaster and its sync. At least now, I know what original MC sync device is. THX!
