motorboatin123
- Jun 20, 2011
- 10
I think my motor is done:facepalm::facepalm:..
1989 thompson twin merc 470 4 cylindars. Finally got the steering cable fixed and the starter. Now the real problems start
Took the boat out for the first long run of the season. After about 30 min of crusing one of my motors started to run hot. (same motor that will not get above 3k rpm after changing cap,rotor, plugs, wires, filters and cleaning out carb). It wasnt "overheating" but it was running on the hot side. Didnt hit the REDLINE so I didnt stop the boat. After about an hour and a half of crusing I stopped and everything was fine. I checked the oil everything seemed good. About 3 hours later I started the trip home and I figured I would check the anti freeze just to make sure its full and not the cause of it running hot. IT WAS EMPTY! I filled it with water and headed home. About 30 min into the trip(with the motor still running on the hot side) the motor shut off. When I looked there was a milky mix of water and oil actually shooting out of the dipstick. I drove home on one motor and that was that. Next day I go to the boat and sure enough if starts right up no problem. I shut it right off cause of all the water in the oil(halfway up the dipstick) but now what? cracked block? Head gasket? Cam seal(but i had one go and it leaked water out of the waterpump not into motor)??? I dont even know where to start. compression test?
