port jeff boater
- Jul 7, 2002
- 50
my 86 four winns 140 mercruiser was taking on water yesterday.. it seemd to be coming in from where the drive is attached to the boat.. last year i had the hot pipe(exhaust)replaced because it was a little coroded at the bolt holes and was also loose.. water was getting in from there last year... it ran fine so far this season but yesterday while anchored in the sound i noticed water in the inside floor of the cuddy. i opened up the engine covered and she was about 2 inches from the bottom of the engine.. the bilge was pumping for about 15 minutes straight. i looked and it seemed to be dripped down the rear of the boat to the floor. any help would be greatly appreciated.. also there are three hoses that are outside the boat to the rear of the drive. two are like boots and one is a 1 inch diameter hose.. the hose and boots look somewhat dry rotted meaning they show signs of cracks but not entirely through could water be getting in from there.. and the recommendation is to have them replaced would you agree,, thanks for all the advice,,,
