help, tilt trim stoped working?
norm64
it worked fine the other day. i did some cleaning under the housing and around the motor wiping down. now when i push the button nothing happens no noise or movment the motor is almost in the full down postion the gadge reads down the motor is a dt 140 14002507528 shifter is na12s button is on the end of shifter. any one know any easy tests to check this
ESB
Re: help, tilt trim stoped working?
norm64,
Did you get your tilt trim problem fixed? The same thing happen to me today. I was out fishing today using my 8hp Yamaha kicker motor and the trim/tilt worked great. We I got back to camp this evening and I cleaned up the boat and was going to flush the motor but I couldn't get the tilt to move at all! On my kicker I have a switch at the motor and at the remote control box up by the steering wheel. Neather switch will work... I'm thinking it must be an in-line fuse but I can't locate one. I don't have the manual with me so stuck. If anyone out there has any thoughts on how to fix this problem please let me know.
Thanks
norm64
norm64,
Thanks
i did not get any helpful info yet, i aslo looked for a fuse blown but could not find one
scottmach1
If the motor's not even running when you activate the switch/es it's obviously an electrical problem. Do your other electronics still work?
If it worked before you cleaned it up, maybe you knocked a wire loose on the motor or a connector pulled off. Even if everything looks OK, wiggle the connections to make sure they're tight and making good contact.
norm64
i looked at all the wires that i could find and didnt find any thing that seemed loose all other systems are working fine, i guess i will have to do somemore wiggling
