Help on fuel line convertion on 10 H.p. johnson
piggy
I've seen instruction for other motors but I need help for Johnson 10 H.P. model QD14 & QD15. Need instructions how-to, also what pumps, were to get, and about cost. As always many thanks.
samo_ott
Re: Help on fuel line convertion on 10 H.p. johnson
A '53 and a '54. You can get a newer bypass covers for those engines from a modern engine that will just screw on and then attach the pump to it. (it might even have a pump still attached to it!) I think 1960 on will have em (or '61). The original Part# is 301848, and it's the same up till 1958 but that's all I have to look at on the parts lists.
