Re: help on building up my transom
Consider converting the outboard shaft length instead of the boat transom. It will look normal, and keep the center-of-gravity down. I just converted the shaft length on a 28hp Johnson, which were only made as long-shafts. I had do do a lot of looking, and maybe I got lucky finding an old place with buckets of old outboard parts that I had to pick through, but I removed the 5" lower housing spacer, and got the shorter shafts and tubes for less than $50. Most places would have wanted triple that, if they had the used parts, but compared to new, even that would have been worth it. Let me know if you want details.
