Re: Help! Marine Plywood For Stringers!!!
While pressure treated has it's advantages, you need to find the old CCA treated, the new AC2 eats most fasteners unless they're stainless. The other problem is that most all pressure treated needs to dry a good month in order to get any kind of a bond with the resins.
The notion of PT wood having poor bonding and eating fasteners is a common misconception. Although there may be an issue with aluminum. Stainless steel, galvanized and silicon bronze fasteners are not affected.
Regarding bonding and the APA tests:
All tests on the untreated and treated specimens at the 65% relative humidity failed predominately in the plywood, indicating a good fiberglass bond. This indicates that the treatment did not have an adverse effect on bonding at this moisture level. Furthermore, the strength of the treated and untreated plywood were similar.
65% humidity! Geeze, the pressure treated ply I get from the lumber yard is drier than that!
Read the whole APA test document here:
http://glen-l.com/wood-plywood/fiberglass-plywood.html
Here is a quote from MicroPro, producers of AC2 pressure treated wood regarding fasteners in AC2 wood:
Fasteners- MicroPro? technology offers many benefits including significantly improved corrosion performance. MicroPro AC2? pressure treated wood with MicroPro technology exhibits corrosion rates on metal products similar to untreated wood. For best results, use stainless steel or Midwest Manufacturing Premium Triple Coated Fasteners.
Fasteners (and other metal products) for use with MicroPro AC2 preserved
wood products include:
- Stainless Steel Stainless steel fasteners and connectors are recommended for use with treated wood in other severe exterior applications such as swimming pools, salt water exposure, etc. - Type 304 and 316 are the recommended grades to use.
Other fasteners and hardware as recommended by the manufacturer
There may be additional products (other than stainless steel or hot-dip
galvanized) which are suitable for use with MicroPro AC2 treated wood.
Please consult with the individual fastener or hardware manufacturer for
recommendations for use of their products with MicroPro AC2 treated wood.
