NJboater65
- Dec 1, 2009
- 3
I have a 1990 200 hp Evinrude on my boat. It starts and runs relatively fine. However, no matter how many times i squeeze the primer bulb, it does not get soild. Even after its running for a while, it does not get solid. Do I have a problem? The bulb is new and all the lines are tight. (FYI, the fuel comes from the tank, thru a fuel/water separator filter, exits to a hose, thru the bulb, thru a hose which goes to the motor. Right before it hits the carbs, there is a in-line glass type filter) Any help/thoughts would be appreciated! Thanks, Ken
