adamsanders
- Apr 22, 2019
- 18
I’ve noticed that the captains chair in my boat is getting extremely loose, to the point I know something will break if not addressed. At some point the previous owner “shimmed” the seat as seat in the pictures below with two pieces of wood but they have gotten loose and slid out. It looks like there are 4 bolts that go from the track into the fiberglass pedestal and I believe the nuts on the inside must have loosened up? Either way, I assume I need to remove the 10 or so screws around the bottom of the pedestal and then I can remove the entire assembly? Does anyone know what I can expect to see under the fiberglass pedestal? If anyone has advice or insight I would appreciate it. Thanks
