Greasing up Pigtail Connection?
You guys think that it would be okay to put axle grease on the connection for my tailer lights? it would help with pluging and unpluging and help keep moister away. But would it cause any harm?? :confused: <br /><br />as always thanks and see you on the water.<br /><br />"At least that's the way that I see it"<br /> -Grumpy Wise Old Man
Boatist
Re: Greasing up Pigtail Connection?
Use WD40 or a Silacone spray.
blifsey
Or how about the special grease made for electric connections at Radio Shack. Don't know how it would hold up & work with a connection you plug/unplug often.
crab bait
don't use 'axial grease'.. go to a 'true value hardware store' or home depot..buy alittle tube of aluminum wire non oxidation compound.. <br /> <br />brand i have is made by GB..<br /><br />i put it on every non solder electric connection.. bulbs , plugs ,ect.. <br /><br />N E V E R .have any green gremlins.. EVER..<br /><br />alittle tube will last a lifetime..
gewf631
Or White Lithium grease - multiple uses, and has dielectric (non-conductive) properties.<br /><br />Just my $0.02
Seaboo2
The corect stuff is called Di-electric greese. You can use it on Spark plug wires, light bulbs (and sockets),any thing electrical you want to greese and (semi) watherproof. I use it when I crimp stuff on an automobile that I want to make sure it doesn't corode (easialy).
