Hello iboats!
I have been reading posts for about a year to build up the courage to tackle my current project. No, not the kitchen remodel that I told my wife 2-4 weeks tops (5 months ago) but a 1973 Glastron V-156. Lucky for me there is a lot of great info already posted for this boat and small fiberglass boats in general so I haven't had to ask any new questions but now that I am buried knee-deep in rotting transom and fiberglass dust some issues have popped up. Here is what I have done so far:
1. Removed motor and interior. The motor currently sits on an engine stand in the garage.
2. The deck has been separated from the hull and completely removed.
3. The floor has been completely removed but I still have some grinding to do on the edges.
4. Today I ground off the fiberglass mat and scooped out the transom (most of it).
Here is my issue (at least the only one I am going to talk about today).
I scraped all the rotted wood off of the transom area. I am a little confused on how far I scrape to. Right now there is a very thin layer of wood that does not chip off without chipping the glass off underneath it. Here is where it get's more confusing. Under this wood/glass layer there is woven roving and it is dry (no evidence of resin). The rest of the hull uses the same roving but it is completely cured with resin. I started chipping at the wood/glass layer along some cracks which turn out to be due to issues on the outer side of the transom. The gelcoat is cracked and indented around one of the motor mount bolts.
This is getting long so I will cut to the chase.
1. Do I scrape the wood/glass/woven roving off down to the gel coat or do I want to leave a layer of fiberglass?
2. If I am supposed to leave that last layer of glass but it is not cured correctly (my dry mat issue) where does that leave me in terms of options?
Here is a current slideshow link that hopefully shows the details :
http://s812.photobucket.com/albums/zz41/wacov156/?albumview=slideshow
Thanks!
Thanks!
