Gen 2 water and oil hose
jonny rotten
Gen 2. What outdrive water and oil hose can I buy at the auto place so I don't need to buy a kit. It's a hose, It's underwater but I cant imagine I need OEM. I thought I read the oil hose is a non permeable fuel/oil hose sold by the foot but not sure. What sizes. Thanks
Jmunk
For the gear oil hose you need one rated for oil. Here are some options and what I believe is OEM:
Parker PUSH-ON B704 or Dayco Eastman B704 1/4" ID 300 psi
Parker PUSH-ON B704 1/4in ID. Part number: 32-8M0040618
https://www.ebay.com/itm/1725128023...McYd9XESkm&var=&widget_ver=artemis&media=COPY
Will need a foot of the gear oil hose and trim down to around 10”.
For the water hose I would 100% spend the money on a molded hose.
Bt Doctur
agree, pre molded is the best way to go, I leave the oil hose a bit longer to help prevent breaking the PLASTIC transfer fitting
