DeepBlue2010
- Aug 19, 2010
- 1,305
I always used wax at the final coat of the gel to grantee curing and I had no problem with it. Recently, I learned from ondarvr replies to some gel/resin related questions that the use of wax could be a little problematic. Granted,, most of the scenarios he shared with us are relevant to factories and mass production of boats but there are few comments he made that got me thinking. For example, he mentioned that continuous rolling (if the gel applied by a roller) can take the wax away from the surface. Also he mentioned that if the temp is hot enough, the gel will cure before the wax gets a chance to migrate to the surface. On the other hand, if temp is cold, wax will solidify and will not be distributed evenly in the gel.
Ok, so maybe using wax is a little tricky to get right. So what is the alternative? PVA
But PVA is not trick free either. I read a lot that PVA needs to be applied at a certain point of time, what is this point of time? Moreover, how to maintain this point of time if we are spraying/applying gel to large area. For example, assuming that this point of time is when the gel starts to tack, this is just an assumption to make the point but I am not sure it actually is the right time since I never used PVA, and assuming we are spraying a large hull; the first area sprayed will start to tack while we are still spraying the rest of the hull ! So this "best point of time" will be a moving target and will vary by area; How can we handle this.
Another question is regarding dealing with scratches. I don't prefer to wet sand/buff them away because this will reduce the longevity of the gel. The whole thickness of the gel is less than 1 mm or less than 30 thou. Each regular buffing and shinning session takes 1-2 thous out of this - if not more - depends on how aggressive the compound that was used. With that said, if we add wet sanding to the mix, the service life of the gel will be significantly reduced.
I am thinking, instead of sanding them down, why we don't build them up by adding gel paste and sand that down. Is there anything wrong with this?!
If the answer is no, I have few questions
1) Why the gel repair shops don't do it this way and insist on sanding the scratch down?
2) What is the correct recipe of making gel past. Few years ago, I ordered Spectrum past and dealt with it. I also made my own by adding cabosil to the gel but they were not the same. The paste from Spectrum was very sticky like it has glue into it. the closest I can describe it is cold honey. Adding cabosil reduces viscosity but it doesn't add this glue effect to the gel. Is there a trade secret we are not aware of?
3) No matter what filler and what not will be added to the gel, should we catalyze based on the quantity of the gel only or the sum of everything? In other words, should we catalyze before or after adding any additives whatever they will be?
