I have a 66 9.5 Evinrude that I just bought. When the motor is laid on its back, gear lube runs out the exhaust port. This is not 2 cycle oil, it lets gear lube out and it lets water leak in as well (at least its getting water in the lower end). What seal do I need to replace to cure this, and would I be better off just changing all the lower end seals in it as I don't know the history of this motor?
Also, the first time I ran it on the boat, it jumped out of gear a couple times then it quit doing that. Should I be checking for a specific problem when checking out the lower end?
One last question, using a mixture of 50:1, this engine seems to smoke more than my 6 hp does, a lot more. Does this sound like a carbon problem? It runs VERY strong at high end.
I look forward to your expert opinions on this!
Larry
Larry
