I have a 2014 DF115 with approximately 36 hours. The overflow from the fuel vapor separator is leaking.
I have taken it apart a half dozen times. If I blow through the fuel inlet the needle seats and I can not blow through it. Flip it over I can blow freely. It seems to be properly seating. I have adjusted the float height more and more.
It seems that there must be something else causing this overflow. Is there anything else in the system that would cause the bowl to fill and overflow that is somehow bypassing the float and needle?
In idle if I hold my thumb over the vent they the fuel is leaking from it builds pressure, seems to anyway on my last reassembly. After it leaked the last time I shut it down and decided to take a break. I’ve been working on this leak for 6 straight hours today. Time to try something different.
Thanks for the help.
